Results 1 to 4 of 4
Thread: Power steering problem, need some help
    Ive got a 1997 C1500 truck with a 5.3 from an 02 silverado. Im running the stock steering gear box in the truck and the stock power steering pump on the 5.3. at low rpm I loose power steering. I thought maybe it had something to do with the 5.3 pump not pumping enough for the gear box at low rpm so I put a pulley from a 3.4 car on it and still no change. Could it be a bad power steering pump? Its full on fluid, and i dont think there is any air in the system and no foaming in the resevoir. Any help would be awesome, thanks!
    http://i295.photobucket.com/albums/mm122/JMinor00/chevy-1.jpg
    White 1992 C1500 RIP, lost to fire
    Orange 1997 C1500 Autocross truck
    Aug 2012
    Lorena,Tx
    Might be worth replacing the pump... no squeaking or whining ?
    2000 GMC Sierra
    Quote Originally Posted by 93GMC View Post
    At first no but after driving it for a little while it starts to whine
    Mar 2013
    Long Beach California
    i had my lines reversed and it whined at higher speed. but there was also foaming though unlike yours. id double check your lines and if that isnt it, then id throw a new pump on.
    CALI LEGAL ENGINE SWAP!
