I need to rebuild my 5.3 I got for my rock crawler, and wanted to get some advice on what all I can and cant do with my budget. I would like about 400hp but more is always better. I would like to use alot of the stock parts to keep down cost and availability.
What is the limit for the stock rods? I would like to add a bit of compression and possibly run it on E85. I figured decking the heads, and maybe some good pistons could get me to that limit.
Also, what camshaft would you guys recommend? I cant run a really high stall converter due to overheating issues and its just a pain to build alot of RPM to make it over stuff. I need to be able to be on and off the throttle alot, and I will have a big cooler with fan.
Would I need to run larger injectors for the E85? What about the fuel system? Can i just use a Walbro pump for 400hp on E85?
I appreciate the help guys, this is what its going in...
