Results 1 to 9 of 9
Thread: not firing after swap
    Ok Im getting power and ground to the coils but no spark at the plug. Does anyone have the wiring schematic for the crank sensor plug on a 2001 5.3? I also might need the schematic for the cam sensor plug also. Thanks
    San Antonio, TX
    do you have a scanner/hptuners?
    I dont have one.
    The ckp wiring is correct . Im thinking the crank sensor is bad. What would be a good scan tool to buy?
    San Antonio, TX
    usually one with bi directional controls, or hptuners.com
    while cranking, you can verify there is crank signal and cam activity.
    then tune it when you're done.
    Nov 2011
    New Brunswick, Canada
    I been through the same thing when i did my swap. I pulled out alot of hair and spent lots of money on parts i didn't need. After everything else checked out, i got a junk yard computer just to prove what it was. The truck wouldn't run but at least i knew it was the problem. Back to back i got two bad computers in a row. Corrupt tunning. Just try another computer, its worth a try. Wish i tried it long before i spent so much time on it!
    Quote Originally Posted by jeast View Post
    Im getting another pcm shipped to me to see if thats the problem.
    Got it running, with help from lextech I got the cmp and ckp
    Sensors wired up correctly and she fired right up!
    Quote Originally Posted by chevy_addicted View Post
    congrats!
    Simple: 408 on steroids!
    single digits coming soon!
