Results 1 to 10 of 11
Thread: 98 C1500 Tach Dont work?
    Apr 2013
    I just fired the engine for the first time and all my gauges work great except my factory tach. Any ideas? I plugged in my Tech 2 and the only codes that showed up were P0650 (because Im not using a check engine light) and P0654 Engine speed output Circuit.
    Mar 2013
    Long Beach California
    was the pcm tuned for it?
    CALI LEGAL ENGINE SWAP!
    Feb 2012
    I had to solder in a 680 ohm resistor to get mine to work.
    12v+
    680 ohm resistor
    |----------------------------------->pin10 from pcm
    |----------------------------------->tach
    San Antonio, TX
    if his definition of doesn't work means no movement, then it's not the pcm and pcm's aren't tuned for it.
    however, the pcm can be tuned for needle adjustment.
    no movement is probably wiring or in very rare cases, a faulty pcm.
    Apr 2013
    It doesnt move at all.. When I get home today I am going to check my wiring again.
    Feb 2012
    Before I added the 12V+ to mine, it didn't move at all either
    Mar 2013
    i may be wrong but the reason i mentioned the pcm is because i thought the tach gets its signal from the pcm on pin 10. and on the newer pcms, you need a 680 ohm resistor as LS2Goat pointed out. i used this diagram http://lt1swap.com/lsx_tach.htm as most guys on here also do to hook mine up. durring one of my conversations with brandon IIRCC, he said the pcm can be set for however many cylinders you are running.... maybe i misunderstood and thats NOT how it works???? if not then what is the pcm doing?
    i agree with LS2Goat, check the resistor thing as that may be your problem. what year pcm do you have?
    Apr 2013
    It is a 04 Blue and Green connectors. I figured I would get a little movement from it.
    Apr 2013
    Quote Originally Posted by LS2Goat View Post
    12v+
    680 ohm resistor
    Took care of it! Thanks alot!!
    Jan 2007
    Lewisville,TX
    12v+
    680 ohm resistor
    Would this be the same on a 95? I get no movement from the under hood white wire, but i did get some from the white wire behind the glovebox.
    95 Chevy, bagged and bodied, LSx swap/detail in progress
