Results 1 to 9 of 9
Thread: Help installing 90 Burb Cluster in 79 C10
    Feb 2009
    Madison, AL
    I did an LS swap in my 79 C10. 2006 LQ4/ 4L80E.
    I want to install the cluster out of 90 Burb so I have electronic speedometer. I searched the forum, but can not find what I need for a 79 C10.
    I used a Painless harness for the swap.
    Do I need to re-pin the 79 connector for the cluster? and where do I connect the VSS input?
    Another possibility -Is it possible to just replace the old speedometer with the 90 Burb speedometer and wire it directly to the PCM and not change out the complete cluster? I have all my analog gauges working with the old cluster.
    Any help will be appreciated.
    Jun 2011
    College station tx
    I think the 87-91s were still cable driven with a box at the speedo for the computer. You can get a box for about 400 that will take the vss signal and make the mechanical speedo work just google "Electronic to Mechanical Speedometer Box".
    [/SIGPIC]
    Feb 2009
    Madison, AL
    1990-91 Suburbans have electronic speedometer clusters. I have tried to attached a photo. I have the cluster, but I don't know how to wire it to work in my 79 C10.
    Jun 2011
    College station tx
    See if you can get a wiring diagram for the 90 burb and find the VSS signal wire in cluster to hook to your vss output from the pcm to. Sorry I can't be more help I had access to alldata when I did my swap.
    [/SIGPIC]
    Sep 2012
    Quakertown, Pa.
    Your wiring may be similar to what I have with my '93 truck. I wired the speedo directly to the PCM red connector pin 50. I have a '99 harness so you probably want to double check to see if it is the same on your harness. According to LT1swap.com., your pcm pinouts should be similar. You should have a dark green/white wire at pin 50 on the green pcm connector. That wire is the 4K output wire. That controls the speedo.
    According to my '93 wiring diagram, the instrument cluster plug has a light blue/black wire in the S position of the plug. That is the speedo wire. Just cut the wire and solder the wire from your new pcm to the end of the wire so as to reuse the little connector in the plug. Your speed should now work.
    Good luck.
    John
    Feb 2009
    Madison, AL
    Really appreciate the information. I will look at the harness and PCM tonight. Harness is a Painless harness drive-by-wire and the dash cluster is out of a 1990 Suburban.
    Feb 2009
    Madison, AL
    I completed the install of the 1990 Burb cluster in my 1979 Chevy Silverado. I traced the harness on back of each cluster and re-pinned the connector to match the 90 cluster. It took a couple hours to get everything in the right place, but now all the gauges and the speedometer work.
    I took pics of everything before I made any changes so I could reverse the process if I could not get things to work.
    Thanks for all the feedback for help.
    Sep 2012
    Quakertown, Pa.
    Glad to see everything worked out. Let us know how you are enjoying your swap.
    John
    Feb 2015
    Quote Originally Posted by dayman View Post
    Dayman,
    I need help can you send me picture and also tell me which color wire you used from the 1990 Cluster to connect to the LS swap VSS. I have 1984 c10 and I'm doing the 5.3 LS swap with 4L60E tranny. This is the last thing i need to complete the project.
    if you would like to email me with pic
    velken2010@yahoo.com
