Results 1 to 5 of 5
Thread: 243 heads question
    Jan 2013
    Bay Minette Al
    243 heads question
    I have a silverado with a 5.3 in it. A friend of mine has a set of 243 heads from a trail blazer ss. He says by putting them on my 05 silverado 5.3 it will gain 30 hp. Is this true?
    05 silverado 4x4
    Pittsburgh, PA
    hes getting that number probably from the GENIV trucks having 243s and being 30hp stronger....theres more to that number then just the heads...the cam, intake, compression and heads made the 30hp difference
    so answer your question no you wont gain 30hp, what you gain in flow youll lose in compression...it be a toss up
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jan 2013
    Bay Minette Al
    Thanks. I had a feeling it wouldn't be worth the time and money for the swap on a stock motor.
    05 silverado 4x4
    Jan 2012
    DFW, TEXAS
    Quote Originally Posted by Contentsunderpressur View Post
    I could use them for my 4.8
    Apr 2013
    Weatherford TX
    you would have to have the flat top pistons that come in the new 5.3 to get that extra 30HP
    05 Z71 Crew Cab 370ci LQ4 with ported and milled 317 heads and a 224/220 581/581 lift on 116 LSA cam
    Longtubes custom y pipe magnaflow cat-back,K&N CAI,4:88 gears, 7 in lift,20x10 Eagles with 35X13.50 Cooper Discoverys. Level 3 built tranny,40000gvw cooler and 2800 Torque Converter. Tuned by the best at BlackBear.
