Results 1 to 3 of 3
Thread: Spacer between engine and accessory brackets on front of 6.0
    Jun 2009
    Caledonia, MI
    I was wondering why my truck has a spacer plate between the acc brackets and the engine? There is only one of them, and it is almost an inch thick with 3 holes in it that goes behind the alternator/power steering acc. It is trianglular shaped
    Did your motor come out of a car?
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by Botlfed View Post
    No it came out of a 2wd 3/4 truck. It was a spacer for an aux air compressor...i tried taking it off because its ugly but then it throws the belt alignment off?
