Results 1 to 10 of 12
Thread: FS: DJM Lowering Kit 3/6
    DJM Lowering Kit 99-06 2WD. $150 LOCAL PREFERRED. This will lower your truck 3/6. Items missing from the kit:
    - Brace for the C-Notch
    - Bolts for the brace
    Items you get:
    - shocks
    - flip kit
    - stock hangers
    - hardware
    - 3" lower control arms
    Here is an image of the parts for the 4/6 drop from DJM. But the only difference with my kit is that its a 3" lower control arm.
    http://djmsuspension.com/wp-content/...djm2599-46.jpg
    Dec 2004
    San Antonio, TX Area
    Does anyone know if these will fit a 2004 Tahoe?
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Oct 2011
    San Antonio TX
    The front suspension is the same I believe. The rear is a four link with coils on the tahoe/suburban/avalanche. All gm trucks from 67 to date are leaf spring rears.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    blanco,tx
    Is this the same kit you promised me? For free?
    Wichita Falls, TX
    Quote Originally Posted by RS/SS 4.8 View Post
    They will NOT fit a 00-06 Fullsize SUV, and I think you might be thinking of 73+ pickups being leaf. My 71 has the triangulated two link type setup with coils, can't think of its proper name at the moment.
    The front end on the SUV is the same torsion bar setup as 4wd pickups. The arms are different in a few ways. The actual mounting points are a further distance apart I think, if that's not the case I stand corrected. I do know for fact that the rear lower mounting point with the bushings is 1/2" longer than that of the 2wd silverado. Also, the SUV arm needs provisions for the torsion bar.
    Quote Originally Posted by twodogs View Post
    haha PM me if you really want it!
    Wichita Falls, TX
    I need the rear shocks, I almost want to buy the whole thing just for the rear shocks.
    dooo it
    blanco,tx
    [QUOTE=ducky;503879]haha PM me if you really want it![/QUOTE
    Its okay, just had to f**k with ya!!! GLWS
    Bumpppp
