how hard of a swap would this be, and what would i need to get it done?
4.8\5 speed\3.23's\Airaid TBS\Flowmaster 40 Series Muffler\Volant Power Core CAI w/ Scoop\0/2 Drop\
What exactly are you thinking of doing? Are you looking at an e-Rod? Or just trying to get a used LS3? Fit wise there shouldn't be any issues. You'll have computer issues, as I believe there is a difference in reluctor wheels between the '03 4.8 and a newer LS3. Even if yours does have the newer computer, it would definitely need a tune to compensate.
- Paul J.
2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
(SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
(SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
(SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
(SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
the lingenfelter trg-002 conversion box(58x-24x) is what he could use or change the reluctor wheel/crank trigger and cam timing gear. either way you could still use the pcm thats in the truck now.
Here's all you do:
get the 58x to 24x ling box.
tap sides of block for gen 3 knock sensors, no drilling needed, just tap the holes, of course you'll have to extend the harness.
you'll need a 4bolt to 3bolt throttle body adapter, ebay! unless you're gonna use the stock 90mm, then you'll need the torquerush.com adaptor box
extend the cam sensor wiring.
your truck has a single fuel feed line, simple connect that to the ls3 intake rail.
injector clips are different, so cut your old ones off and give us a call for some ls3 injector clips; forget the truck adaptors, they suck, imo.
you'll need a tune, the stock injectors are over 40lb'ers, it'll foul the plugs if you start it with no tune.
just to be clear, you'll use the stock truck harness and pcm.
good luck,
allen
everything else is just basically installing the engine.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
yes
Nelson Performance
NP on Facebook
Youtube Channel
cool, one last thing, if i could get an ls3 out of a new camaro with all the accessories could i just drop it in like that?
Red 94 GMC Sonoma
Red 94 Jeep Wrangler
Red 02 RCSB Silverado
Red 03 Ford Cobra
Red 04 CC Silverado
Red 05 Yamaha Raptor
I really like red
Double Post.
You are over thinking this too much, you need to look for a LS3 that is a long block with intake. If you are looking for big power though for the price of the LS3 you could easily build a motor, save money and avoid the headaches of changing all the sensors.
Red 94 GMC Sonoma
Red 03 Ford Cobra
Red 04 CC Silverado
I really like red
