Results 1 to 10 of 38
Thread: lq4 idling high
    Jan 2012
    lq4 idling high
    Lq4/4l80e swap is 95% done. Its idling high. Not surging or anything just idling high. Any thoughts
    Jan 2012
    DFW, TEXAS
    leak somewhere, or stuck (carboned) throttle?
    Jan 2012
    Ten four ill check for leaks. Tb is new.
    Jan 2012
    My dbc tb has a port for pcv and so does my dbw intake. I capped intake and am using the tb port. Is this right
    Jan 2012
    DFW, TEXAS
    any pics? can you hear where the leak is coming from? or grab a can of throttlebody cleaner and spray it
    Dec 2010
    Quote Originally Posted by cottontop11 View Post
    Try flipping this and see what happens?
    Jan 2012
    I hooked the otc to it. Its idling at about 1050. Tps is at 0. I sprayed it with starting fluid looking for vacuum leaks didnt find any. It drops to about 950 in gear
    Do you have a tune?
    Jan 2012
    Yup np tuned. I think i found it. Sprayed a healthy dose of starter fluid around cylinder 3 manifold gasket and she changed pitch.
    Jan 2012
    Intake gaskets didnt fix it. Im still hunting though
