Available stock apearance builds. Set up a Dana 60 on this crew cab on a low budget.
Had no problem keeping all stock parts "INCLUDING ALL BRAKES AND ABS!"
Ive got a fullsize blazer 4x4 with a 10 bolt. I want to go corp 14 but they are so heavy. My vehicle probably already tips the scales at 6k. How would you beef the ten bolt up.
Well you can try trussing the housing, buy you can only go so far before it becomes very bulky and ugly.
As far as inside a good set of axles, differential, and a main girdle cover.
right point there.need it to be replaced is the best one
led lights
How much for this set up if brought you truck? And whats down time?
That's some good work!!! I've seen all his work on the latest trucks he's been posting.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
