Frist let me say this is a very helpful site and to the crew at Nelson's these people are top notch to all you guys thank you the wiring harness and tune looks great now I need to start my swap thank again guys
My truck is 93 single cab short bed 2wd has been converted to 4wd solid axle front
In about 2 weeks it will have its very own ls motor 5.3 thumper cam Nelson harness and tune
A solid axle obs, sweet.
Best ET 11.54@114 w 1.52 60ft
Raceweight 4905 lbs.
I love the axle swap work so much better . I have some pics I'll get them posted up as soon I figure out how
Info on the thumper cam? SAS will be sic!
Comp cams 54-600-11 .553 in 536 exh ls 109 I know it kind small
Also running 2800 stall and 513 gears with 37 in tires
Am I correct in saying that the 109lsa makes it very rough idle, why it's called a thumper?
Yes but I wouldn't call it rough but SWEET just saying its the hot rodder in me
Ok here a pic of her
