Here's what I'm seeing...per instructions in the cruise control/speedo wiring thread I should be looking for a blue wire/black stripe and red/white stripe.
I see neither of those, this is what I have
Which wires?
Which wires?
95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
Also after looking around and seeing some diagrams for older trucks I see that they have a smaller connector, my DRAC has a slot for a smaller plug but I don't see the plug anywhere and I've never even messed with the drac. Did '95 trucks even have them hooked up?
Used the dark green wire, speedo is working. Said piss on cruise control, I've gotten used to not having it, maybe I'll find out where the hell that plug is eventually. Now I'm having an issue getting the DRAC to lock back in place and it's starting to rain![]()
My 93 had one, never messed with 95 but not thinking they did. Pretty sure VSS ran straight to the computer
Cruise control for a race truck?
hmmphh
the very thought of it
lmao, don't worry about it, my TB won't allow my Cruise control wire to hook up to it. you're not alone lol
97 xcab c1500 lm7 5.3 swap 343RWHP 329RWTQ 13.40 @ 101.97 2.03 60ft. MODS: Longtubes, 3200 stall, TR220 112lsa, .030 799 heads, NNBS intake, PTM 92mm TB. 4" PVC "hot" air intake 3" single exhaust w/cutout 3.42:1 gears, 29" tall tires. Dyno tuned by flaco
I never hooked my cruise up either.
BECAUSE RACE TRUCK(s)
On my 94 to get the speedo working, I hooked it up to the solid blue wire. For the cruise control I havent messed with it yet but I thought it was red w/ white stripe
