How user friendly is it? Which version to buy? Where to buy it?
Nelson Performance sells it.
Summitracing has them for the best price right now..
06 CC 4/6 drop
Its 500 for standard and 650 for pro through them. That's the same price it is everywhere. You cannot get HPTuners through a retailer for less than $499.95.
http://www.summitracing.com/search/Brand/HP-Tuners/
They also give you $50.00 in summitracing buck.. I just bought one
http://www.summitracing.com/parts/HPT-6011/
06 CC 4/6 drop
Actually you will also get a $15.00 summit bucks coupon on top of the $50.00 as well, every $500 you spend you get one.. Does HPtuners work on an engine swapped vehicle??
HP tuners is pretty user friendly if you just do some reading and only adjust what needs adjusting. The main thing is to read before you start tuning. I would recommend the pro interface so you can log Air Fuel Ratio easier. However, I don't have the pro so I just wired my Air Fuel Sensor to my old EGR connector and pick it up that way.
That is not a bad deal if summit is giving the coupons!
99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
