Decided to ditch my dbw and go dbc on my lq4 swap. How big of a tb can I put on a stock truck intake. Any tb suggestions are aporeciated
Is it a 3 or 4 bolt intake?
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
three
You can go as big as you want...up to 90mm but the opening on the intake is still only 79mm. Best bet is a ported and polished stock 78mm or going a 4 bolt truck intake from either a TBSS or a NNBS 4.8 or 5.3. If you did upgrade intakes that would let you go up to a 90mm without having a neck down at the opening.
Thanks
