Results 1 to 6 of 6
Thread: Transmission line adaptors
    Sep 2011
    Anyone know where I can find an adaptor that will screw into where the transmission line goes on the 4l80 an I need it to have a 6an on the other end of it so I can make my own transmission lines out of hydraulic hose I have at work.
    Jan 2012
    D/FW
    check ebay....see them all the time. trans fitting to -6 AN.
    1968 GMC - Carb'd and cam'd 6.0 LY6, 200-4r, 3.73 posi 12 bolt
    2006 TrailBlazer SS - 13 sec. grocery getter
    Sep 2011
    I seen them but I figured I'd ask before buying them
    Jun 2009
    Caledonia, MI
    IF its for 4l80e get these.........http://www.sweetperformance.com/prod...&productId=496
    because the rear line has the extended tube on it, that mose tranny adapters dont have
    Sep 2011
    That's exactly what I'm looking for! What do most aftermarket transmission coolers come with? Am I gonna need another adaptor to be able to hook up to it?
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by jansen View Post
    I used summits kind, but the one didnt have the extended tube that goes farther in the tranny. Mine work, but they have a better chance of leaking.
