Results 1 to 10 of 13
Thread: Oil Pressure adapter help/PN #'s
    Jun 2009
    Caledonia, MI
    I am trying to figure out the RIGHT adapter I need for putting my old Oil Pressure sensor on my new block. The adapter I bought from speedway motors isnt even close to being right. Anyone have a reference to the correct one or know the thread sizes?
    18mm male and 1/8 NPT? Little bitty fitting for the OP gauge, right? If not then you have the one that is 3/8" NPT. Is it too small for your sender?
    Jun 2009
    Caledonia, MI
    My adapter is to small on both ends. The end that screws into the block is to small, and the hole that the sensor screws in is to small. so the sensor wont screw into it.
    Jun 2009
    Caledonia, MI
    And the stud on the sensor is a big guy. looks like its 3/8.
    This is what it says on Speedway motors... 12mm-1.5 Male to 1/8" Female. You obviously have the 3/8" fitting. You could swing by you local hardware store and screw it into a threaded pipe to verify size. 12mm is way too small.
    it is a 16mm male and whatever size sensor you have, maybe 1/4" but likely 3/8" NPT.
    These are the sizes available from S&P that are a little more expensive. Click the pic to enlarge.
    if it's 3/8 on the end it's probably a 1/4" NPT. Go verify size before ordering another one.
    Jan 2012
    warwick ny
    http://www.ls1truck.com/forums/lsx-t...ed-swap-3.html There is a picture in this thread with part#'s
    Oct 2008
    Tennessee
    Speedway Part Numbers:
    Part Number # 182-2277 12m to 3/8 Npt Water Temp.
    Part Number # 182-2268 16m to 1/8 Npt Oil Pressure
