Results 1 to 5 of 5
Thread: Ss hard line ad fuel line
    What are some of your thoughts guys about using ss hardline and -an compression fittings. I have access to plenty of ss hard line in 3/8 to run for my fuel lines and the correct tools to bend and run them just wanted to know what you guys thought about it. I have been researching fuel lines and alot of guys use steel lines and Teflon lined ss braided hose I'm not a fan of rubber hose are the ss braided stuff. My truck is plumbed with ss tubing for my complete air ride set up and leak free and it sees 200 psi all the time so I would think it's a good line to use as fuel line.inputs on this would be great
    San Antonio, TX
    Nothing wrong with it at all.
    yeah i bought some aluminum line not thinking about the pressure ratings from jegs and glad i only paid around 18 bucks for it. i thought i was going to be able to use what i have now also but it's the same material so it's all coming out and getting replaced with ss hard line
    Itll work just Fine.
    Feb 2011
    cleveland
    My old race truck was all ss lines and swagelok fittings and I never had a problem. As long as you dont have to buy the fittings and can get them from work i would do it. Those fitting are high dollar but It looks good when it's done right.
