any one have any idea on what kinda times that i might be looking at with bone stock ls1 in 4wd chevy rcsb 1/8 mile with nelsons hot rod tune????
9.5? Depends a lot on how much weight you're pulling and what final drive ratio you're running. Gears and tire size will make quite a difference. My stock LS1 ran 9.25 with a good tune but weather will wreak havoc upon your times, also.
3.73 with 265/75/16 at 3800 pounds ,nelson tune , 4l60 REMEMBER 4WD
Wow only 3800lbs! You should be about 13.4 1/4 with a good tune. Better than 9 if the weight is true. I think you might be thinking on the light side lol!
