There is a low pressure cycling switch on your old accumulator(silver looking can on the evapator unit) that you can use for the AC request signal to the PCM. There is also a high pressure switch from your trans-am (a 3 wire pressure sensor) that you will need to install on your system so the PCM can sense the pressure. I had mine hooked up this way at first, then I found out I have the variable displacement compressor so I didn't need the low pressure switch. If this doesn't make sense to you I can take pictures. As for EGR they eliminated it with the cam profile on the newer models, but I don't think it would cause any engine harm to run without it.
