Curious i have a 1999 ECSB Z71 and it has what looks like a 3" alum drive shaft. One i see on here are steel and like 2".
Does the Z71 have a bigger driveshaft ?
Yes, the Z71 driveshaft is shorter and has a wider diameter made of aluminum. I was told it was shorter dont know the exact dimensions.
'02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
2013 GMC Acadia: SLT1 Carbon Black
1976 Corvette Stingray: Trying to save it, progress is slow.
^Ricky's Sweet PS Skilz
09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
I don't think it has anything to do with Z71 vs non-Z71, I have seen both styles on both types of truck.
As far as the diameter, an aluminum shaft has to be wider diameter to have the same strength as an equivalent steel shaft.
I don't know why the alloy shaft would be shorter, that doesn't really make sense, but there couldn't be much difference even if they are.
Honestly for off-roading, I would rather have the smaller diameter, less easily dented steel shaft.
