So my truck has developed a new issue.. when you go into drive from rev or park there is a delay with a "slam" in actual gear... Trans acts perfect other wise??? Fluid level is good and not burnt.... any ideas???????
2005 GMC Seirra CC SB z-71, Stock for now
Are you positive its not a u-joint, carrier bearing or rear end issue?
yes.. no clanking or hesitation when going into reverse.
