Anyone got the dimensions for the LS1 motor that comes out of the vettes with the short balancer? I can't seem to find them on the net anywhere. Thanks in advance...![]()
the approximate distance from the round bosses on front cover to rear of torsional damper pulley.....
pn 12560115 Corvette (.600")
pn 12553118 Camaro/Firebird (1.000")
pn 12553112 C/K Truck (2.250")
will that work for you?
Thanks Red but I was actually looking for the total dimensions for the motor. Like total length and width to the furthest points. If you got those specs that would help. Thanks again.
Maybe this will be of some help. This is the marine vortec 6000 engine. It should have the same basic dementions of the ls1 engine.
http://www.gm.com/automotive/gmpowertrain/...6000_marine.pdf
I thought you had an LS1 in your Sierra. Measure it and subtract the difference between your type motor and the Vette motor. They're all the same blocks dimensionally, just different drive pulleys and brackets. Since you have the truck pulleys your engine is 1.65" longer than the Vette engine at the crankshaft pulley. I don't know how much further, if any, the water pump sticks out on the truck pump though. I am sure it is about the same amount as the difference between the vette and truck pulleys minus the fact that the vette has never had an engine driven fan in a LS1 powered version.
JRhino, those look like the dimensions I emailed him. Great info!
LS1/ LS6 & LS1 Based Truck Engines
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
yea i just forgot to measure it up real good when I had it out... was too excited to stuff it in the truck. Thanks for the info guys.
