Results 1 to 7 of 7
Thread: Got the truck back from Allen Nelson Nelsons Performance
    Jan 2006
    Got the truck back and it is slow? JK!
    It is crazy fast! I took it out this evening to test drive and wow! The WCCH heads are bad to the bone! I think when it cools off I should hit 11's in this 3/4 ton truck! The boost comes on very strong now. I did look the old heads over and I had a broken valve spring? Allen caught it when he took them off. Also the turbo log was cracked in several places. They welded it back up and it is good to go! I thought my truck was fast with a broken valve spring and cracks on the turbo log, now it is just crazy! There is absolutely no traction in 1st or 2nd!
    Thanks Nelson Performance!
    Jamest
    badass,and nice truck i seen it out there...
    Aug 2009
    Fort Riley, KS
    cant wait to see your new times
    04' RCSB, LQ9, Front mount T76, TU1, Circle D 3K, Built 4L60E, True Trac, 3.42:1, 4-6 Drop
    Jan 2006
    Id say after driving it, if I can hook up it should be in the 11's easy. We will see when it gets cooler outside!
    12 Sec. Club! SOLD
    SOLD***
    Arizona/Utah
    Sounds wicked lets see some pix and vids
    Sep 2010
    x2 on the pics and vids, sounds mean.
    2007 RC Silverado aka ?
    1998 Trans AM aka Red Dragon
    Jan 2006
    Let me see if I can get some
