Results 1 to 4 of 4
Thread: OBS AC wiring Question
    Jun 2011
    College station tx
    Can any body who has ran the LS style compressor on the 96-99 share how the wired the the ac compressor. I already know about the possible freezing up and I've already nocthed the frame for the compressor. Done alot of searching and cant figure it out.
    San Marcos Texas
    What is the compressor off of? A f-body compressor is variable displacement and would be wired differently than the truck compressor for instance.
    Jun 2011
    College station tx
    03 Truck
    Jun 2011
    College station tx
    Can I replace the 3 wire sensor on the high side on the 03 with the 2 wire from the 97? but what about the compressor cycling switch the 03 doesn't have one and the 97 did, is it needed. Also will the F-body A/C lines fit the compressor, if they will that will help with clearance.
