Need to know what clutch I could use for my 6.0ho and fly wheel...I'm stuck can't start till I get that done....any one could help me out
it might help if we knew what trans you are using? i had a t-56 and used the ls7 clutch setup, seemed to work fine for me.
Yeah, it'd really help to know what transmission you're using...
The 2007 LQ4 6.0/ 1991 NV4500 setup in my '87 Jeep YJ uses the following:
• 12" Truck flywheel out of a 2004 4.8 liter (PN# 12561680)
• Clutch and pressure plate from same 2004 truck (PN# RAM88744 OR PN# RAM88793T)
• 6 metric pressure plate bolts (PN# 12561465)
• Clutch slave: ‘92 3/4-ton Chevy external.
Handy tip if you're installing an NV4500: The clutch hardware parts (clutch, flywheel, and pressure plate) in a 4.8 liter with an NV3550 are the same part numbers as those used in a 6.0 with an NV4500 (RPO: MW3).
HTH,
Jake
