Fender flares
Does anyone know of fender flares designed to cover up the rust above the rear wheel wells? I don't want the factory 4 wd big bulky fender flares, this is a 2wd truck and I am looking for the lowest profile ones I can find. Heck if someone had color matched heavy decal vinyl cut to size I would scuff seal and put heavy vinyl down. Looking for something that hides rust but doesn't look bulky or dorky.
I got an idea. Fix it CORRECTLY
Replace the box and then paint to match on a $2000 truck. No thanks. I'm just looking for a band aid and I think I stumbled across it this afternoon- http://www.jegs.com/i/Putco/730/97110/10002/-1If they look Gucci I will just buy a pint of summit white and paint them.
- You may not post replies
- You may not edit your posts
