Ok ladies.
I just arrive from a "relaxing" (yeah right, who relaxes with a ton of hot chics in thongs and your wife at your side) trip to some paradisal Islands, so now I checked my emails, and got little to no answers to my needs.
Since you all have become technical here, let's TECH "THis" :
You all might know by now (including some lurkers form Ecuador that live on this site just to know what happens to my truck...LOSERS) that a few weeks ago my truck went down "because" the 2 u joints from the Drive Shaft were decapitated.
Now with new CSI evidence, we are not so sure what happens !!!!
History goes like this:
*Rolling make a wot, and by 70mph thing went "boom"
*DS stood at the DS Clamp so no damage to this was done...but
*seem that vibration kill the aluminium bodies of TC and 80e
This was solved, and when everything was in place, truck did not move.
After this Mechanics took Diff Cover out and encounter Spider gear pin broke in 3 parts (spider kit was changed 2 month ago)
Further disabling showed Pinion damage too (received photos at my email when I was away)
Know evidence points that the first part to give up was the Diff, and that make the Pinion angle a 2Nd matter. This and the weakness of the 1430 u joints did the rest of the job.
Some pics here:
Now since some or few know my OEM rear end is a variable from the D44HD use in ZJ or rubicon Jeeps (98-07) the question is:
Theories of how and why this happens?
Should I keep the housing and upgrade everything inside (pumpkin for locker, beefier axles, etc.)?
Or should I buy a new rear end assembly from Mosser, Strange or any of those sissy vendors, that BTW don't have a direct bolt on for my application !
Now that you have been cleansed up.....go tech ladies....show time !
