Results 1 to 10 of 11
Thread: Valvoline oil question
    Union, MO
    So I know everyone had their own opinions on oil, but I have a question. We purchased a vehicle care plan with my 2010 Silverado which covers oil changes and tire rotations. I was told the dealership I go to used Castrol GTX but found out they use Valvaline. I've read that Valvoline oil leaves a waxy residue in engines and that it's not a very good oil. I'd rather use Mobil 1 synthetic like I have been for that past 8 years, so if this is true about Valvoline, Ill just go the oil changes myself.
    2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
    GM is supposed to use Castrol, dealer must be getting the Valvoline cheap. Like the GM dealer I worked at got a better deal on Lucas synthetic, so anything that was supposed to get Mobil One got that crap.
    Union, MO
    Maybe it's penzoil I'm thinking of. Either way, we are paying $15 more a month for this service so I would technically be throwing that away every month.
    Jan 2011
    Mcalester,okla.
    valvoline is a pretty good oil, and it doesnt have a residue,its pennsoil that leaves a build up, because it has penzaine in it, i ran valvoline for 6 years in my 5.3 and when i tore it down it looked clean as a whistle, so i say go for it. i now have a built 6.0 and run moble 1 cause its high performance and on spray
    I run Mobile 1 in the 6.2. That's what it came with from the factory, so that's what it gets. I ran GTX 5/40 in my 4.8 and my 5.3. That's what it is supposed to get, so that's what it got.
    Valvoline VR1 and alot more spray, mobile 1 no thanks
    Simple: 408 on steroids!
    single digits coming soon!
    Jul 2009
    Valvoline is great oil. I've ran 4 years of conventional and 2 years of Syn Power and when i tore it apart at 86k it was very clean
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    DFW
    Pensoil and quakerstate are both perifin based oils while valvoline is ash based. As long as you change your oil often and regularly, and as far as conventional oil goes, it really dosen't matter. It when you wait until 20k miles to change conventional oil that you run into problems. That and oil additives.
    2006 Black Vortec Max Crew Cab 4wd
    TR224-112
    UD pulleys
    160 stat
    Vette Servo
    4.10's
    NP Tune
    20 x 10 Tezzen TRX-1
    Toyo Proxes ST II's 305/50R20
    Coming Soon: 6" RCX NTD, 20" TR BeadLOOKS, 35" Dick Cepek FC II's
    Round Rock, TX
    Valvoline VR1 here also
    Missoula,Montana
    Mobil makes the non-synthetic Gm branded oil also.
    '00 1/2 TON ECSB 5.3L 4L60E
    K&N Filter,Gibson Exhaust,Superchips Programmer,Billet Servos,'03+ Taillights,White Door Handles,Carbon Metallic Grille Emblem,6000K HID'S
