01 5.3l silverado
I have a TR224 .563 lift cam. I am about to install some new 918 springs. Assuming my install height is 1.8, should I shim? Comp Cams told me not to shim. Others have said shim .030
Any help is appreciated
Jason
01 5.3l silverado
Jason
01 RCSB, 5.3, TR224/112
4.10 w/ Auburn
3200 Fuddle, HD2, Vette Servo
Nelson Tune, LT Headers
shimming hurts heat exchange from the valve springs to the heads, so unless its necessary its not recommended
Really? That GD HKE shimmed mine. 030".
to my knowledge shims are used to ensure that the valve spring has the proper load at installed height. Some may need them some may not.
2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
