Results 1 to 6 of 6
Thread: Newer gauge cluster in an obs q's
    I have a gauge cluster out of an 01 sonoma w/tach 7k rpm. I want to swap this in with my 06 lq4. What I'm wondering is if the gauges will work with that comp? I.e. Water temp, oil pressure, battery? Is my fuel sender gauge signal from my 92 the same as the 01? Finally just wondering about the vss from my 92. I know it's different but is there a way to convert it to work with the 01 cluster? Sorry lot of q's on or post.
    and I call myself a mechanic...
    Upon reading an scouring the web I have found a lot of info on the vss issue. Apparently tbi trucks had a 2 pulse(or 2000 pulses a mile) signal where as 96 and up had a 4 pulse? So Im guessing I can use a newer sensor in place of my 2 pulse and it should work IF the reluctor wheels are the same which im hoping they are. Anyone feel free to chime in...
    Nov 2010
    Durant, Ok
    I am interested in if and how it would work, but I have no knowledge on the subject
    Josh ----- 95 Z71 ecss -6.0 swap finished 10k miles ago, nelson tuned, built tranny, 2800 converter, 4.56s truetrac
    2000 z28 a4 longtubes, true duals, ported throttle body, ls6 intake, slp lid (lost in divorce lol)
    79 camaro small block street car 11.60 @ 116 (sold)
    From what Ive found so far most the gauges will wire in just fine- battery, water temp, oil pressure. The speedo should just be a matter of changing out my vss for one from a 96+ as apparently all gm reluctor wheels are the same. I believe the tach should be fine but Im not sure considering the gauge is from a 4cly and Im running a v8. Ill keep lookin into it.
    Quote Originally Posted by Bobilly View Post
    They changed after 07 from 24x to 58x.
    The reluctor wheel I was referring to is the VSS reluctor wheel in the transmission or the transfer case on 4wd. Sorry for the confusion.
