Results 1 to 7 of 7
Thread: 5.3L Build
    Mar 2011
    5.3L Build
    Hey guys, new to the forums. Here is my 5.3L build that will be going in my Black 1992 C1500. Things Done: Chromoly rings, SDPC Z+221 Cam ( 221/226 .565/.560 114 LSA ), ZO6 upgrade valve springs, double chain billet timing set ( had to clearance the front cover ). All new cam bearings, rod bearings, main bearings, seals, gaskets, o-rings, freeze plugs. Honed cylinder walls, machined heads. Just finished the grinding, cutting and sanding on the top of the stock manifold, going to be painting it a flat black. A set of red aluminium fuel rails and steel braided cross over ready for that. Red MSD plug wires. Ordering starter, alternator, power steering pump and a set of JBA silver ceramic coated shortys in 2 weeks. Then just wiring harness / ECM, flexplate spacer and motor mount adapters. YAY!
    Mar 2011
    more pics
    more pics of the build xD
    So Cal
    sounds like a sick build man, got any pics of the truck?? hey why r u going with shorty headers? proly get better flow with LT's
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Mar 2011
    Quote Originally Posted by DAmarcus28 View Post
    truck is dropped, thinking im going to have upper arm clearance issues but the JBA shortys can flow. they have a cone built in the center of the collector to increase transitional smoothness from the primary tubes to the collector, internal welds, 14 guage steel, 3/8 flange. For some reason i cant find a picture of the truck, i have tomorrow off ill grab a couple then.
    Oct 2008
    Houston, TX
    how low is ur truck? mines about as low as can be and dont have any issues.
    btw its not the one in the sig.
    Airaid, alpine double din,
    Arizona/Utah
    Plenty of boys here with LT's and fat drops. Ask some of the heavy hitters more than one riding low enough to touch the ground out their windows haha
