Silverado SS & Silverado non-SS parts interchange?
Will a grille assembly from a 2004 Silverado SS work on/fit a 2004 Silverado that's not a SS? Thanks.
* 2004 Chevrolet CCSB Z-71 5.3L * G80, 3.73's * Black Bear Autocal 91 oct tune * Magnaflow 3" SI/SO 14" case * Airaid M.I.T. * OEM airbox with open air modification * Color matched grille & lower valence * Blackened Tail Lights * SuperBright LEDs in brake lights & reverse lights *
In the garage to be installed: 799 heads, Dyna-Tech long tube headers, Corvette servo, 2" lowering shackles, 2wd u-bolts & bumpstops
![](image.php?s=5a08d5d47438110db00704f72d6fabc3&u=9665&type=sigpic&dateline=1366259766)
- You may not post replies
- You may not edit your posts
