Results 1 to 10 of 13
Thread: finally picked up an LS1, got a few ?'s
    motor & trans are from an 02 camaro. i'm putting them in my 96 fullsize chevy. my main questions to start are about motor mounts & drive shaft.
    i've searched the forums but can't seem to find definate answers so hopefully someone can answer them here.
    i've been told some motor mounts push the engine & trans back & i'll have to get my drive shaft shortend.
    i've also been told there's mounts out there that put the LS1 in the factory position & everything will work fine.
    next is the trans question. is the trans from the camaro the same length as the on in my truck now?
    i was told the camaro trans is shorter so my drive shaft will have to be made longer.
    i see a lot of people doing this swap but nothing ever mentioned about modifing the drive shafts.
    if anyone can shed some light on these questions for me it would be greatly appreciated.
    Mar 2010
    Midland, TX
    I would suggest you grab a tape and get your back dirty. Take plenty of measurements, having a driveshaft shortened/lengthened is nothin for a machine shop.... but then again my best friend owns one. I think I've read a few builds and remember that the driveshaft will need to be modified.
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
    well i found some motor mounts on ebay that have 3 positions, stock, 1" forward & 1" back so i think those are the one's i'll be getting. from everything i found last night searching the transmissions seem to be the same length. now i just need to figure my exhaust. the motor didn't come with any exhaust manifolds so i'm not sure if i want to go with stock manifolds or put out the cash for headers.
    Same same length
    Dec 2004
    San Antonio, TX Area
    I used some very similar to these.
    http://cgi.ebay.com/ebaymotors/LS1-L...item53e5c40c1c
    but mine were from car shop inc.
    http://carshop.carshopinc.com/produc...id/74328/LS1GM
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Mar 2010
    Midland, TX
    If you want to go stock 5.3 exhaust mani's I have a set I'll let you have for $20 + shipping
    Shopping List
    Quote Originally Posted by Chevy-Art View Post
    did you have to do anything to your driveshaft?
    Quote Originally Posted by BigMac View Post
    how much you think for shipping to 70001?
    Mar 2010
    Midland, TX
    I think you'll be better off getting some locally... $40 to ship to that zip
    Shopping List
    Dec 2004
    Quote Originally Posted by RPM Graphics View Post
    I used the stock drive shaft and didn't have to do anything to it.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
