What converter should be used with this cam
These Xtreme RPM cams from COMP Cams have been designed to increase horsepower and extend the rpm range of your engine. From stock replacements to ultimate performance, there is an Xtreme RPM cam to meet your performance goals.
:Specifics:
# Basic Operating RPM Range: 1,500-6,800
# Duration at 050 inch Lift: 212 int./218 exh.
# Valve Lift with Factory 1.7:1 Rocker Arm Ratio: 0.558 int./0.563 exh. lift
# Lobe Separation (degrees): 115
# Grind Number: LS1 XR265HR-15
