I am listing this build for a client who can not afford to finish his build. He stopped by today and paid me to finish the engine, and asked me if I could sell it or knew any one interested in it. So here it is:
(Ill Put What He Spent Under My Accounts, And What He's Asking)
Prepped LQ9 block with 25K on it, $900.00 Spent (Machine Work, Ported Galleys, Cam Bearings, Surface, Sonic,)
Scat Crank 4" Stroke STD / STD 24X $400.00 Spent
NEW Scat H-Beam Rods $600.00 Spent
New LS2/LQ9 GMPP Pistons/Rings/Pins $375.00 Spent
King Race Bearings (CIrcle track HH2-1) $150.00 Spent
Balancing Rotating Ays $300.00 Spent
LS3 Heads Ported/Hollow IN/Sodium EX .570L Spr $1,200.00 Spent
New Stock LS2 Cam $350.00 Spent (Yes it has the LS2 Cam Cover and Sensor Port All you need is the harness extender)
Head Mill To 69cc $80.00 Spent
LS3 Rockers/Bases $ 160.00 Spent
New LS2 Timing Set Up $60.00 Spent
New Ported LS3 Intake /Injectors/Rails/TB $475.00 Spent
ARP Main/ Head Studs $400.00 Spent
Gaskets/Seals $120.00 Spent
LS1 Valley cover Powder Coated RED $40.00 Spent
LS2 Timing Cover Powder Coated RED $50.00 Spent
LS1 Rear Main Cover Powder Coated RED $30.00 Spent
Vented LS2 Valve Covers Powder Coated RED $125.00 Spent
L92 Truck Pan/Pickup/Windage Powder Coated Red $175.00 Spent
LS3 Intake Cover RED $50.00 Spent
TOTAL SPENT IS $6,040.00
My Labor On The Build Is $700.00
SO TOT WITH LABOR IS $6,740.00
HE IS ASKING $4,900.00 Plus Shipping.
I had my builds mixed up with the LS2 block in this post...
I will have picks of the "Exact" engine up in all its glory ASAP, I do have picks of the Vented covers and Coated Stuff from a different build but it looks the same.
I will be finished this weekend. UPDATE PICKS BELOW!!!
