To help get a better understanding of cam timing I have been doing some research. The cam I am using for example is the stock 5.3 LM7 Cam
So I understand that it takes 190* for the intake to open and close and 191* for the exhaust to open and close when open and closed is determined at .05" and that the midpoint of the exhaust opening and closing are separated by 114*. I've heard that sometimes the cams begin to open a few degrees before or after TDC. What I'm trying to understand is exactly when does the intake begin to open specifically on a stock 5.3 LM7.190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
Also, is there any information available on ignition timing? I would like to know what the typical ignition numbers are for idling, highway cruising (~65MPH) and WOT.
Thanks for any help in advance, just trying to expand my knowledge of the engine.
