Results 1 to 10 of 15
Thread: !! starting obs 6.0 swap!! got some questions! plenty pics!
    Jul 2010
    hey fellas im startin my 6.o swap in my 1998 stepside! the old 350 juss isent doing it any mor lol it fulley bolted on trutrac with 4.10s and rebuilt 4l60e with billet servos and tuned by flaco. he told me he said a man ur not never ganna be happy till u do a ls swap! lol
    and here i am 8 months later lol
    i picked up a complete pullout out of a 03 6.0 lq9 with 60,000 miles with complete harness and computor and gas peddle for 1700 flat delive to my house.
    iv gather a bunch of parts already but still need but still need need help with a couple parts hopefully yall guys can help me!
    questions
    wat intank fuel pump can i use i know i need 5o psi or so in the line.
    flexplate. i know i need to run the new 6.0 flex plate but herd i need to get a 4l80e flexplat spacer. in this true?
    adapter plates. iv got the transdapt plates cause when i got my shienfiled long tubes they said they will work with thows plates. some people are talkin bout need the 1inch set back plates is this true??
    will the motor sit in the correct spot so my trans will bolt up in the rite spot and 2 piece driveshaft also or do i need the set back plates??
    any help is appreciate guys thanks!
    heres some pics of wat i got goin on rite now!
    the chosen one!!
    lq9
    com/upload/files/509/IMG_0455.JPG[/IMG]
    parts!
    8.1l injectors
    tsp torquer v.3 231/234 .643/.598
    f body pan and pick up tube
    and seramic coated shienfild lt's made for obs ls swap
    what yall think!!???
    Jul 2010
    my truck
    Jul 2010
    mounts
    injectors
    Jan 2011
    Central Kansas
    Talking 6.0 into 1997 StepSide
    5.7Stepside: I am on board with ya, I am getting ready to do a 6.0 into my 1997 4X4, I bought it with a blown 5.7, I then installed a TPI 327, lost the water pump, fried the motor so blasted quick. WoW!! any way when taxes get back I am purchasing a 6.0, already have the '411PCM, and program for the setup. I am a metal bender as a hobby, you can see one of my creations here http://www.flickr.com/photos/tinbend...7615870852729/ the only EX-CAB 53 Willies in the world, and I built it, in 17 months. As such I will be Creating most of the stuff I need to complete this. planning on attempting the building a better AC mounting system for this swap. please document as much as you can. and we can share notes. If you have an issue that I could Possibly build an answer for you, please let me know. Or if I find an issue I'll let you know. cool?
    to answer your questions, the stock Vortec pump will work, someone said that we will need a corvette inline regulator?? and as far as I can find out you do not need the setback mounts unless you want to move trans and build new drive shaft as well. why are you changing the injectors? flex plate kit here http://www.crateenginedepot.com/stor...P2399C120.aspx
    I am not following you on the trans and headers issue, please explane more and maybe a picture?? I think the LS will bolt right up to the stock trans??? not sure, I'll check it out and get back to you.
    Jan 2011
    Central Kansas
    got a look at the back of an LS looks good to me!!
    Looks good. The engine will bolt up to your original 60e transmission using the 80e flexplate after elongating the bolt holes a little, do that before putting it on the engine. You're going to like the new powerplant in there but the modding has just begun.
    Jul 2010
    weell juss wanted to go a lil bigger on injectors ause i red up on a guy who was doin a build almost just like mine big cam and his tunner told him the dyno dhoed he was flatlineing a little bit cause he was runing shoot on fuel afte 6,000 rpms. i juss figgured they would go go the can take fuel away better to have mor now and take away thge be short fuel and have my truck be down waiting to by injectgors. lol
    and the fuel pump so many people say and iv jected my self all ls motors in 50-52 pounds in the line in order for the motor to run and my pump in my puts oy maxx like 36!
    Jul 2010
    mor parts
    Jan 2011
    Central Kansas
    the pump in my '97 can push 80psi, I know because I jacked the regulator on the TPI all the way up to see what it could do, I would double check your actual pressure, as ALL Vortec's are regulated at 60psi, this was a major issue on my TPI. (never got it worked out, as stated earlier she is fried) if you are pushing only 35psi, you need to find out if the regulator is bad or if it is indeed the pump
    Feb 2010
    Where did u get the headers?
