Driveshaft Lengths? post lengths of all driveshaft from all combos.sc,ec,cc,ssb,sb,lb
I'm trying to find out if I can use a stock replacement shaft for my truck (2007 nnbs cc 1500 5'8 bed with 5.3) that will work with an 80e. I think I have the same wheelbase as a ecsb. So I'm thinking I might be able to use a driveshaft from a ecsb that originally had an 80e. Does anybody know? Also if this driveshaft doesn't work do you guys know what will?
post all combos if you can shortbed longbed single cab extended cab 5.3 6.0 8.1 6.6 you get the picture.
THanks ahead for your posts!
2007 GMT900 CCSB 5.3 VTS2300 Twin Screw Supercharger, Doug Thorley LT's, True 3" Duals into Dynomax Race Bullets, Nelson Tune, 4L80e w/transgo HD2-D, Truetrac, 4.10 r&p
Need list: Stall, PLX 200 for my crappy AFR, X-pipe, GM 20's.
