Has anybody done this before? I was looking for a used 6l80 when I came across a steering wheel with paddle shift from a 2010 Vette. Anybody know if it would be possible to do a conversion? I think that would be a pretty sweet setup
2007 GMT900 CCSB 5.3 VTS2300 Twin Screw Supercharger, Doug Thorley LT's, True 3" Duals into Dynomax Race Bullets, Nelson Tune, 4L80e w/transgo HD2-D, Truetrac, 4.10 r&p
Need list: Stall, PLX 200 for my crappy AFR, X-pipe, GM 20's.
i was going to try and run the stock column tap shifter from a denali/escalde when i do my 6spd swap well see
Will they hold a gear in "M" mode or do they have an idiot backup and still shift on their own?
My "M" option holds until redline. If I drop it in 1st it will automatically fall to the idiot backup and shift for you. The manual option on mine is only good for braking w/ a trailer, takes waaay too long to shift effectively.
- 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
Shopping List
- Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
