can you use 6.0l heads on a 5.3l i know that the cc is different the bore to valve size
Bolt pattern is the same
You can, not sure why you would want to unless you're going forced induction.
i have a 5.3 short block with 20,000 miles on it and i have a set of 6.0 heads i was going for a low budget build, i am going plane the head to 58 cc and port and polish i like them for the bigger valves
Not gonna have much surface left after that much milling...
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
Lol that's ALOT of milling
1983 Ford Ranger- 2.3 to 205k mile 6.0 swap
Unless ur going forced induction you will lose compression and hp, and if u mill down that far ur intake wont mate up, ur head to intake deck hieght will b all wrong.
i did'nt think of that i could mill to the same cc of the 5.3l heads i mostly want the 6.0 heads for the bigger valves
just use the 5.3 heads and have them ported they will work just fine
2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
You could get a set of ls6 heads. They are the same as the 317 heads your have but they come with a smaller cc chamber. It is 64cc compared to the 71cc of the 317 heads you have. The casting number for ls6 heads is 243 or 799. You wouldn't have to mill as much and still have some room to mill more if the heads become warped. They also have the same size valves as the 317 heads.
SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
