I don't have any experience with destroying a 60e. I've never owned one. But from what I've been reading, if you make much more power than stock with bolt ons and a tune and you plan to drive aggressively a 60e will become a money pot with no bottom. I've also seen people claim that they have been running well over 500rwhp through a stock 80e with a shift kit with no problems. I've seen it said that the stock 80e is stronger than a race built 60e. If that's is all true than does the few% tq loss really matter to you? I don't see how it could. Seems like it would b cheaper to make an extra 25ftlbs than it would be to repeatedly repair a 60e. Just plan your rear end ratio and tire size around the very tall 1st gear ratio found in the 80e. The truck in my sig doesn't shift out of firsts untill over 60mph and can't spin the tires for more than a few feet on dry pavement. And its putting about 360 ftlbs to the ground. I'm getting either 4.88 or 4.56 gears next mod.
99 silverado 2500 4x4 ec lb, lq4 with 243 heads, pace setter long tubes, true duals with x pipe and bullet mufflers, comp 222 224 112 cam, 8.1 truck injectors, 4l80e with 2800 stall, 373 gears, 285 75 16 tires, efi live tune in progress, 350rwhp 360tq, 11.8 average mpg mixed driving
