Results 1 to 10 of 11
Thread: Caltracs vs. longbars?
    Feb 2009
    Okeechobee,Fl
    Ok guys ive noticed that some guys (including one of my friends with a cummins) are starting to run longbars rather than caltracs. I plan on building a set, but im not sure which ones yet. The longbars for me would be easier but if they dont work as good Ill make a set of caltracs.
    So mainly my ? is what is the difference in the 2?
    Robby-2003 Regularcab stepside, 5.3, 93 Nelson tune, 3.73 and Grenade 80, 2/4 drop, 22's LQ4 and 4l80 in garage waiting to be installed!!
    1967 Chevy pick-up, torch red, LS6 454 w/mods, 4/5 drop, 18inch Boyd
    Okeechobee, Fl
    Oops didnt realize my dad was logged in, this is for me, not him...
    49 Ford F1
    Basically Cal-tracs work by using axle wrap to push back down on the springs, long bars just don't allow axle wrap.
    Houston
    the reason your cummins buddy is using long bars is because all the cummins guys use them and the reason is because thats whats used for sled pulling, the longer the bar you can get the better, where as for the track you want a shorter bar
    edit* thats tboth traction bars caltracks are a little different like french said
    Cal-Tracs wont bind up the suspension either.
    Houston
    yep they are alot better for daily driving BUT you wont be a stock suspension truck anymore
    Okeechobee, Fl
    Ok, so will the long bars hook as good as caltracs? Im not worried bout binding the suspension cuz i dont go anywhere cuz its too low..
    49 Ford F1
    Houston
    you want short bars then, not long bars like i said short=drag long=sled pull
    When it's actually warm enough again I'm building a set of bars for mine, that way I can just take them on and off when I go to the track or when the truck is Saturday night special mode. I was trying to think of a way to have a shackle in the front of them so they wouldn't bind and then have a way of locking them solid when I need them and came up with a couple ideas. Just have to see
    Okeechobee, Fl
    Oh ok luke i got it now. Im prolly gonna have my buddy build me a shorter version of his then, since he already knows how to do it..
    Ya Devon that would be pretty cool if you could get some that u could remove!
    49 Ford F1
