Results 1 to 8 of 8
Thread: ls s10
    ls s10
    i posted this here because i will add my progress here later. im finishing up my 5.3 swap in my s10.
    My question is i have a chance to get a comp cam for $50 but not to sure bout the numbers
    its 3712r/3717r
    from what i have looked up its 0.563/0.571 218/228 114
    just wondering if this would be a good cam for a stock 5.3 4l60e setup. right now its on the stock stall
    and rearend. once i post the vid on here you will see.
    plans are a 8.8 rearend, cam, nitrous, and stall.
    93 ECSB...lq4 6.0 swap, 255 walbro,cai, ported tb, shorty headers, 3" exhaust, tune,electric fans, NX wet kit 100 shot, 2/4 drop, beltech shocks, boss 335 22's, 295/30/22...looking for a cam.
    heres the vid, not sure if it works. im at work where theres no player installed.
    http://www.youtube.com/watch?v=JAUvUXS-nPM
    just got the exhaust done...2 1/2 y-piped into a 3" flowmaster dumped before the axle.
    where did you get that coupler for the steam vent tee into your upper radiator hose?
    i made it. 1 1/4 steel pipe, drill a hole, welded a nut and installed a 1/4" brass fitting.
    Anyone?
    did you bead roll the steel or not?
    i would try to run a real mild cam if you dont have a stall converter or supporting mods.
