And whats the difference between the LQ9 6.0 and the other 6.0? Is there a difference in the heads too?
http://inlandempire.craigslist.org/pts/1996990162.html
Thanks
Thanks
2007 GMT900 CCSB 5.3 VTS2300 Twin Screw Supercharger, Doug Thorley LT's, True 3" Duals into Dynomax Race Bullets, Nelson Tune, 4L80e w/transgo HD2-D, Truetrac, 4.10 r&p
Need list: Stall, PLX 200 for my crappy AFR, X-pipe, GM 20's.
or how about these 317's?
I don't know what heads are the best for my 5.3 or what is actually compatible.
thanks guys
http://inlandempire.craigslist.org/pts/1968265988.html here's the link
Unless you are going with some serious boost, I doubt you want the iron heads. You can get 317s super cheap all day long. The LQ9 has 317s too. I wouldn't use them on a 5.3 though, compression too low. What are your goals with your engine?
Yeah it is a nnbs but I don't have the slightest clue what heads I have. I just read on some other forums that the 5.3 heads aren't very good. are you saying the nnbs heads are better than the
317's? How can I find out what heads I have? Is there a stamp?
Also I thought there was a difference in the lq9 and 317's. I remember it being the valves but IDK.
Well, if it is a NNBS 5.3, it has the 799s or 243s. Those are different heads than used on the NBS 5.3. They outflow the NBS heads but lose compression slightly, which isn't a bad thing in your case since you're boosted. The 317s are rarely used on a 5.3. They drop compression too much. They do flow well though when they've been worked a little.
