this is what i ended up fabbing since no one makes swap mounts.
I used these mounts on the block
just kinda curious if anyone has ever mounted a motor like this im hoping it doesnt rattle my truck apart.
Are you going to use any sort of bushings?
no i already have the motor in. i would have like to but being that no one made swap mounts i kept it simple. is it going to be an issue you think?
i dont think it will be a problem but it may be a little noise and u will feel EVERYTHING that engine does
Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
EPS cam 23x/23x 600/603 112lsa
KP 6 link bagged with Accuair E-Level
http://www.nitrousexpress.com/
There's A LOT of guys runnin ls motors in s10s...check out s10forum.com I'm sure someone makes an almost bolt in motor mount. Solids will work...your lady friends won't like it (or they might lol)
I took my stock mounts and took some scrap metal and welded them up solid.. Been like that for several years now.
-Tyler 2000 ECSB-370-Vic Jr-FAST 4150-244/248 .612/.615 112 lsa
