Results 1 to 5 of 5
Thread: I'll try
    Oct 2010
    Post I'll try
    Hey guys is it possible to make 500-550hp with stock heads and cam in lq4? and can I just use stroker crank with stock rods and pistons?
    "I've never heard of extra money" and"It only cost too much because I dont have enough"
    Jul 2009
    At the motor yes. Bolt-ons, tune, exhaust, and 150 shot of haterade would put you there. Why use a stroker crank with stock pistons and rods? While you have it tore apart go big or go home. Why rebuild it bigger and not change cam, or get head work done?
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Oct 2010
    Money is the reason, but I still am gonna put a cam in it with the stroker crank. I didn't want to spray though. I thought about not doing stroker and getting 243 heads and cam with ls6 intake. Just gonna freshen motor up with bearings and rings. I figured that if I put a stroker crank in then I would raise compression and still get good power with 317 heads.
    Birmingham, AL
    Quote Originally Posted by sb50 View Post
    uhhhh....
    01 Silverado
    i didnt realize this was serious. is this serious, or is someone making a joke, reminds me of the epic thread, when that ricer said his engine went in reverse.
