Results 1 to 9 of 9
Thread: have i got the wrong engine mount conversion kit???
    hi all i got a trans dapt ls1 engine mount adaptor kit see link provided, The plates bolt up to the engine but the new mount that is supplied in the kit is to small and wont fit over my engine mounts that bolt onto the chassis! is it just a case of ordering new engine mounts that bolt onto the chassis or do i need a new kit?? if i do need a new kit can someone provide a link to the kit i need please? cheers ryan
    http://www.summitracing.com/parts/TR...n/?prefilter=0
    are you saying you removed the factory rubber mounts off of the front engine crossmember and the new ones won't bolt back in place of where the old mounts were? Is this a 2wd or 4wd truck?
    correct, I have what i think they call "clam style mounts" im pretty sure, truck is a 2wd i will get some pics up!
    May 2010
    so cal.
    You just use the trans dapt plates and bolt the old mount that slides over the chassis mount to the trans dapt plate. I bought the same kit and tried to use the mounts that come with it too.
    SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
    Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
    2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
    cheers classic1, i actually had a feeling that may have been the case after i posted this up!
    classic one i just done what you said to do and it will work but as the mount is not flat there is a gap between the original motor mount and the transdapt mounting plate, was your ones the same?
