DBW trouble
I'm having some trouble getting my DBW pedal to work. When i plug the connector in from the TB to TAC module, the butterfly moves around then stops. I can't get it to move with the pedal at all. I tested the pedal position sensor and I'm not getting any type of resistance reading at any throttle position on any of the pins. Is their supposed to be resistance on any of the pins on the pedal pos. sensor? If someone has the schematic that would help a lot.
Thanks
SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
