Results 1 to 4 of 4
Thread: tire and rim??
    May 2010
    el paso, tx
    tire and rim??
    bout to buy some rims 22's. reccomended tire size is 275 45. back spacing is 6.14" with 30mm offset. can i mount my 305 40's without problems?? also, purchasing 2 18's reccomended size is 285 55. back spacing is 5.15" with 10mm offset. could i mount the nitto 555r's at 305 45?
    06ccsb, cammed, stalled, geared
    Jul 2009
    RGV, TX
    is your truck dropped?
    305/40s are what usually are recommended for 22's with a stock height truck. After a drop, 285/35 or 265/35 are the most common sizes to go with, ill be going with 285/40's for my 08 sierra on a 4/7 drop
    2008 GMC Sierra
    1998 GMC YUkon 4X4
    2007 Kawasaki Vulcan 900 Custom
    May 2010
    el paso, tx
    no drop kit just leveled rear
    Jul 2009
    RGV, TX
    hhmmm..
    yours is an 06? those are a few inches lower than the NNBS trucks..... so I might say on stock height you might wanna go with the 285/40R22
    heres what mine looked like @ stock height with the 305/40R22
    as you can see... it still had quite a bit of fender gap...
    so id say your 06 should fit what my 4/7 dropped truck fits. 285/40
    2008 GMC Sierra
    1998 GMC YUkon 4X4
